afr heads????/
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
afr heads????/
i am building a 383 stroker for my iroc, iam getting the zz-9 cam, the big mouth intake and i want to get the afr heads. which afr heads would be the best for the track and a weekend driver?190cc 195cc? 74cc, 68cc, or 64cc combustion chamber? im looking to get the most power i can get, thanks
Car: Damn
Engine: This
Transmission: New Stuff
Well, supposedly the 190s and 195s flow the same, just the 195s are for larger race port intake manifolds. I would go with the 190s with the intake you plan on running.
The rest will determine your compression ratio. The larger cc chambers will make less compression, and the smaller cc's make higher compression.
Is this going to be a N/A motor, forced induction, sprayed?
Are your pistons dished, domed, flat top?
Is the block decked?
You should decide on these before you choose a chamber size.
For example, I chose the 190s and had them milled to 58cc to make around 10.2:1 CR ratio. My block is not decked, pistons are at stock height and stock dish size. With a thin head gasket I get around 10.2:1, which is good for a n/a motor with aluminum heads.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The AFR 195's come port matched to a 1205 Felpro & flow very slightly better at high lift than the 190's. My calculations show with a flat top piston, down .015" below the deck, 68cc chambers & a .028 gasket, a CR of 10.3:1. Which is about where I am at.
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
