Bad MAF??????
Old Sep 30, 2002 | 09:47 PM
NOSFEDGTA's Avatar
Bad MAF??????
Took the car for a ride today and got on it for the first time. When I got on it and let off the gas I had a bad back fire and then the car would not run right. I could get it to start or idle. I thought maybe I blew out the maf, but when I looked at it it was fine. I then unplugged it and it ran fine>?< anuy ideas here.??
Drew
Old Oct 1, 2002 | 09:56 AM
Sciguyjim's Avatar
It's possible the MAF wire could still in place but have a tiny crack somewhere and so is making a bad contact. Plug in the MAF and idle the engine then tap on the MAF housing. If the idle changes then there's a bad contact somewhere.
Old Oct 1, 2002 | 10:36 AM
Vader's Avatar
The ECM monitors the MAF very closely, since it relies on data from it. If a reading is out of range for even as little as 600mS, the ECM will lock a DTC, giving you a nice little reading lamp on the dash.
BumpaD82
Feb 26, 2016 02:57 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Nick McCardle
Sep 10, 2015 08:36 PM
