no spark on tpi swap help!
Old Oct 5, 2002 | 11:56 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
i swaped from tbi to tpi everything is working but i can not get a spark. i replaced the ecm thinking that was it but it wasnt. does any one have any ideas im all out for now. please help soon.
Old Oct 6, 2002 | 03:11 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
are you getting power to the coil?is there power coming out of the coil?have you replaced the ESC(electronic spark control)?have you tried putting on a new cap and rotor?new plugs?
we need a little more info to help you
Old Oct 6, 2002 | 10:30 PM
ZZsmpch's Avatar
You didn't swap in a VATS equipped (89 up) TPI setup did you?
Old Oct 8, 2002 | 04:25 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
We got it fixed, the problem was a dead ignition module. We swapped in an 88 TPI setup, which did not have VATS. We tried the original TBI ESC module, as well as the TPI ESC module. Finally, AJ 92 RS suggested we have the ignition module tested at autozone. The TBI one which we were using tested dead, and the TPI one tested fine, so we put it in, and viola, spark.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
mdtoren
Aug 16, 2015 05:45 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
