Where is the cooling fan switch on a....???
Old Oct 7, 2002 | 08:46 AM
TBIWorks's Avatar
I have an '88 GTA and I bought a Hypertech cool fan switch for it. Where is the factory switch located??? I used to have a '92 305TBI car and it was located on the passenger side head above the knock sensor. Am I blind or is it located somewhere else on the 350TPI cars? Please help, this car runs very hot and I want to get it installed soon, thanks guys.
Old Oct 7, 2002 | 09:17 AM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
on my 87 305 TPI it was on the pass side head between the back to cylinders. It was real triccky to get to. Maybe you are just missing it?????
Hodge
Old Oct 7, 2002 | 12:51 PM
PerfectionGoku's Avatar
Car: 98 Camaro Z28
does that switch screw into the head? and which fan should turn on? the left or the right? i own a 87 gta. 350 tpi.
Old Oct 7, 2002 | 02:06 PM
TBIWorks's Avatar
my car does turn on one of the fans when it reaches about 235 degrees. Not sure which one though, but I know I have to have one cause the fan comes on when it should as set by the factory. I'll look again, I have headers, maybe when I crawled under there the other day I over looked it, but still, I have installed 3 of these in 305TBI cars, so I can't imagine it not being located in the same place on all the later model small blocks. If anyone has an '88 model, let me know for sure.
Old Oct 7, 2002 | 04:42 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
If it is the same on an '89 then the switch screws into the block (not head) on the pass side. It controls the pass side fan operation based on the on/off temp settings of the switch.
I am using the 176* on / 166* off with a 160* thermostat.
-Schultzy
Old Oct 8, 2002 | 07:49 AM
TBIWorks's Avatar
thanks, I guess it was the block on my old car too. a friend of mine insisted it was in the head. I will look again when I have time. oh to make sure the TPI systems are the same, does the '89 have the cold start injector valve sensor too, or was '88 the last year?
Old Oct 8, 2002 | 10:31 AM
Car: 98 Camaro Z28
88 was the last year of the cold start injector if i remember correctly. i know on my 87-88 tpi engine there was something screwed in on the passager side head,
Old Oct 8, 2002 | 07:47 PM
Car: 1989 GTA
OOPS!
My bad. It is the passenger side head (not block). I just went out and looked again. Used to seeing it from underneath - hehe.
Sorry for the bad info.
-Schultzy
Old Oct 9, 2002 | 09:53 AM
Walkersteelhead's Avatar
Isnt the fan switch on the front of the tpi manifold right under the hose. If I remember right thats what haynes called it.
Old Oct 9, 2002 | 03:54 PM
TBIWorks's Avatar
on my '88 there are two sensors srewed into the manifold underneath the TPI throttle body. One is the cold start injector switch, and the other is the engine coolant temp sensor. The fan switch must be somewhere else.
Old Oct 9, 2002 | 05:19 PM
MikeS's Avatar
You should find the switch from underneath. In between cylinders number 6 and 8. Look up past the starter from underneath.
Walkersteelhead,
I think the sensor/switch that you referenced is the sensor providing an signal to the gauge inside the car. The fan is switched by a separate switch.
Old Oct 9, 2002 | 10:11 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
OK...lots of missinformation here. THe FAN SWITCH in located in the head on the passenger side between cylinders 6 and 8. The COOLANT TEM SENSOR that the computer uses in screwed into the front of the intake manifold. the sender for the GUAGE is on the driver' side heads between 1 and 3....
Old Oct 10, 2002 | 09:43 AM
TBIWorks's Avatar
I agree totally with slowiroc, I knew this all along from having owned my camaro. However, I didn't see the fan switch on my GTA on the passenger side between 6 and 8. I still have not had a chance to look again yet. My only question was, is there any other place on a thirgen that the fan switch was factory located, or only in that location between 6 and 8? Because if so, then I have a missing one.
Old Oct 10, 2002 | 10:05 AM
Car: 98 Camaro Z28
on my 87 gta its on the Passager side head between 6-8 and on my 88 l98 recon engine it has a block off for the 6-8, so i guess thats where its suppose to be located.
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
