.060 over 305
Old Oct 11, 2002 | 12:02 AM
JAKEDPLAYA's Avatar
.060 over 305
Can anyone tell me what my 305 became (in cubic inches) when I bored it .060 over?
Old Oct 11, 2002 | 10:28 AM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
311 or 312 I think.
Old Oct 11, 2002 | 11:02 AM
JAKEDPLAYA's Avatar
Does anyone know for sure
Old Oct 11, 2002 | 11:19 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
316 cubes. To find the cubic inches of the engine, multiply bore/2 squared, times 3.14, times number of cylinders, times stroke. For you, that works out to be 3.74" + .060" bore, 3.48" stroke, 8 cylinders. works for any engine. roughly speaking, .030 works out to around 5-6 cubes in the range of 300-450 ci engines, and .060 works out to be 12-14 cubes. hope that helps.
Old Oct 13, 2002 | 09:39 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I think I got 314.9 when I typed it in Desktop dyno. I just rounded it off to 315 and call mine that.
Old Oct 14, 2002 | 07:37 PM
Black91Z28's Avatar
Car: 1991 Camaro z28
Engine: 350 Tpi
Transmission: 700r4 Auto
i thought you couldnt bore out a 305 because the cylinder walls are too thin......must be wrong
Old Oct 14, 2002 | 08:53 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
.060's kinda pushing it. Any bigger and you might as well sleeve it and call it a 350 I bought a rebuilt motor and found this out when I pulled the heads.
Old Oct 14, 2002 | 08:58 PM
f0rmula350's Avatar
is there any way you can tell if a motor has been bored? when they rebuild one, do they always bore it out?
Old Oct 14, 2002 | 09:45 PM
92TRANSAMWS6's Avatar
yeah...you can measure the bore.
Also the pistons will have the over bore size stamped onto them, .030 etc.
Most people/shops will have the engine bored whenever it is rebuilt.
Old Oct 15, 2002 | 01:10 PM
f0rmula350's Avatar
thanks, so what would be my cid now, 355?
Old Oct 15, 2002 | 01:26 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Yes.
Old Oct 15, 2002 | 04:05 PM
f0rmula350's Avatar
thanks.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
dimented24x7
Sep 6, 2015 03:51 PM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
