5spd 305 times
Old Oct 18, 2002 | 08:53 PM
87 B4Z's Avatar
5spd 305 times
what kind of time are you 5spd 305 TPI guys running? im swaping out my 700R4 for a T5 and was wondering if i will see any performance increase with it. also what mods are done to it.
Old Oct 18, 2002 | 09:07 PM
92zeddar's Avatar
14.5 at 96.87....headers,pulleys and free mods!
Old Oct 18, 2002 | 09:12 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
see sig.
ran 14.6 @96 w/ headers, chip, exhaust, air filter.
Old Oct 18, 2002 | 09:47 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I just got back fromt he track, 14.4 @ 97mph w/ a 1 second R/T and a 2.4 60/ft.
It feels good to go half a second faster than my last time at the track. Mods are in the sig.
Old Oct 18, 2002 | 10:57 PM
rezinn's Avatar
5SIZ,
What kind of tires do you have? That 60 foot time isn't too good! But 14.4 with 93mph is pretty good. You see these guys are running .1-.2 slower with 2-3 more mph. Get that 60 foot down and you're in the 13s easily. Sub 2.0s and you could take almost another second off
Old Oct 18, 2002 | 11:44 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
5SIZ, what other times did you pull for the day? Also did you let up before the traps? I think the computer gave you the wrong MPH. 14.4@93 are perfect numbers, but on a 2.4 60' you ethier got the the wrong mph or 60'. One mod for you ET STREETS! I only say that because I work at a drag strip and know that computers malfunction and all thing said and done dont jive.
Old Oct 18, 2002 | 11:52 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
sea levels
hey are those times corrected for sea level? because out here in texas they run close to 14.8-15.0
Old Oct 19, 2002 | 01:16 AM
BORLAZ06's Avatar
Low 14s all day.
I wish I knew what I run.
Old Oct 19, 2002 | 01:18 AM
CheezX's Avatar
14.6 @ 95 MPH w/ 2.26 60ft
Mods: TB mounted K&N, ported plenum, headers, dual exhaust.
I'm gonna change the ripped+broken plug wires and ignition to MSD stuff this weekend. I'm running on 7.5 cylinders right now.
Old Oct 19, 2002 | 11:30 AM
5SIZ's Avatar
Car: 1987 IROC-Z
Originally posted by rezinn
5SIZ,
I'm running on Potenza RE 730's
I know I have terrible 60 ft.s I need to learn how ot friggin launch my car better, it bogs down off the line because I try to feather it to the point wher it won't burn out everywhere but at the same time it will hook up good, int he end when I take off the car almost dies on me LOL.
Old Oct 19, 2002 | 11:38 AM
5SIZ's Avatar
Car: 1987 IROC-Z
Oh im sorry guys, I posted the wrong MPH! "kicks himself in the ***!"
I ran a 14.4 @ 97MPH That sounds a bit more reasonable now oesn't it LOL.
Yea my friend has drag slicks and I'm thinking of taking them out for a spin to see how I do.
Old Oct 19, 2002 | 12:11 PM
vortech305's Avatar
I ran a 14.4 at 94mph with street tires, REALLY BAD TRANNY(t-5) bad coil and leaking spark plug. This was also done with 3.23 rearend, So far i replaced the plug and coil, got Nitto Drag Radials, Rebuilding my WC t-5 and soon to install a 4th gen 3.42 rear, I should hit mid to high 13's
Old Oct 19, 2002 | 10:22 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Much better. Beg, steal, or borrow a set of drag raidials and put that 305 in the 13's.
Old Oct 20, 2002 | 07:55 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
13.53 at just over 100 MPH. Mods are in my sig.
Old Oct 20, 2002 | 06:55 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
14.7@94 with a 2.25 60 ft. worn out throw out bearing, holes in both N10 pipes and in desperate need of a tune up...with a 2.0 60 ft how much would my e/t im prove...not tryin to hijack a post just curious....
bjankuski
damn man u got a ringer lol
Old Oct 20, 2002 | 06:56 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
bjankuski
damn man u got a ringer lol...i bet you worry a few ls1's huh
Old Oct 20, 2002 | 08:13 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I raced and beat a few LS1's but they are always catching me by the end of the quarter. My 100 MPH quarter finish seems like I am standing still when they are running 107 - 108 MPH.
Old Oct 21, 2002 | 11:21 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
middle of the pack
'91 Formula 5L/5-speed best 14.6 and 93.9mph. N10, pullies, Ultra Team. Old clutch, old posi, my 60 foot times are like 2.5 pretty bad eh ?
RP.
Old Oct 30, 2002 | 04:11 PM
chevy power's Avatar
I have heads/cam in my 305 and my trap speed is 105mph. so far the best i can run is a 13.99 w/ a 2.6 ft. i need new tires bad! every one says i'm a 13.50 car but i just need to get those 60fts down to a 1.8. my last run that i got that 13.99 i beat a 99 ws6 T/A. that LS1 didn't pull me in the top end, i pulled him! it was even till about end of third gear. then i waxed his ***
Old Oct 30, 2002 | 10:50 PM
palric's Avatar
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT, Vortec heads, Vortec manifold, ZZ-4 cam.
Best ET street tires 13.53
Best 60 FT street tires 1.903
Best MPH street tires 100.92
RWHP 255.4 = approx 300 flywheel
RWTQ 314 = approx 369 flywheel
Pretty cool setup bjankuski.
I've got a '91 Formula 5sp/305 3.42 with homemade CAI with pullies, N10, 3 inch cat back Dynomax, Jacobs Ultra Team, some plenum work. I installed LCAs, panhard, wonderbar and STB. The car pulled 260hp/336lbs torque on the dyno with this trim (see sig).
I just picked up a set of 3.73s. I'm shopping for a ZZ4 cam, headers and am sending my (GM 081) heads in for 1.94/1.6 valves, springs and some heavy hog work. Going to leave the TPI alone. I think it is a pretty safe bet I'll see 1hp per cube after the mods I am doing this winter.
Curious -- did you flowbench the Vortecs before installing them ? Did they have any work done to them ? Are you going to upgrade your ignition ? What about gears ? I was thinking you have 2 or 3/10ths tied up in ignition and gears ?
thx,
RP.
Old Oct 31, 2002 | 08:14 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Yes, I did flow check the vortec heads, they have been cleaned up but not heavily ported. The intake flow was 246 CFM at 28" water and the exhaust was 170 ish at 28" water. I was thinking of going to 3.70 gears and I am running a stock ignition.
Jake_92RS
Jan 28, 2020 10:37 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Dquickshift
Aug 12, 2015 06:21 PM
