Difference between Hypereutectic and Forged rebuild kits?
Old Oct 22, 2002 | 06:03 PM
firebirdkid's Avatar
I'm gonna buy a rebuild kit from Summit, and I need to know the difference before I call. I'm rebuilding the engine for Nitrous purposes, so which would be better? Thanx guys.
Old Oct 22, 2002 | 07:05 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
i would go with forged.
Old Oct 22, 2002 | 09:09 PM
bigals87z28's Avatar
Car: Check The Sig
forged is a stronger then hyper. ... if ur goin for a motor thats gunna put out over 400+ hp... i would deff. get forged....
Old Oct 23, 2002 | 09:29 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
If they are using KB Silv-o-lite Hyperutectic pistons, you'll be fine with just about any amount of nitrous yuo throw at it. It is documented on their website somewhere that they have run a 400 shot of Nitrous using their pistons. You must tell your builder that you are going to be running juice though. The rings need to be gapped a little differently or the pistons WILL fail however, if they are gapped correctly, you wont have any problems. I have heard this from a couple expereinced builders, as well as the guy I had build my engine.
Old Oct 23, 2002 | 10:43 AM
Thanks guys.
hectre13
Dec 11, 2023 08:14 AM
italiano67
Dec 11, 2016 09:21 AM
Mickeyruder
Sep 2, 2015 02:45 PM
fasteddi
Sep 2, 2015 10:29 AM
