Vortec TPI kit
Old Oct 25, 2002 | 04:46 PM
92RS87Z_Driver's Avatar
Car: 92RS
Engine: 305tbi
Vortec TPI kit
http://www.sdpc2000.com/cart.asp?act...2175&pid=89538
Does anyone currently run this setup? I would match it up with a lt4 hot cam. They stated that they made 375hp with this kit including the cam on the stocl computer and tb. It seems like a good deal for a direct bolt on kit thats had all the machine work done for you. Also, does anyone know if it comes with roller rockers or if I would have to purchase some. Any input is appreciated guys
Old Oct 25, 2002 | 05:48 PM
Morley's Avatar
Send them an E mail and ask about the rockers, I doubt it does though.
Scoggins/Dickey is very good about answering E mails.
Old Oct 27, 2002 | 08:17 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
ok, i know this thread is sorta old and all, but........
I emailed them the very same question two weeks ago, and have yet to get a reply. this is not the first time that they have taken forever to reply to me. If you find out, post it here. or if anyone on here knows, please do the same
Old Oct 28, 2002 | 01:01 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Good luck getting an intake (Vortec TPI base) from those guys, they have been on back-order for 2 1/2 months!!!!!
Old Oct 28, 2002 | 04:51 PM
DownUnderIROC's Avatar
Yep I've had my Vortec TPI base on order for 2 months from SDPC, still waiting.......
Old Oct 28, 2002 | 05:27 PM
GTAracer's Avatar
Old Oct 29, 2002 | 05:37 PM
mckenzie's Avatar
how does this setup sound, 98 vortec heads, 88 L98 350 block, the vortec/tpi intake, and cam mod's while i have the engine out? what cam would you suggest? i don't want to burn a prom, just use factory chip and computer. thanks, tom
Old Oct 29, 2002 | 09:15 PM
Car: 92RS
Engine: 305tbi
Still no response from them yet. All I saw in the ad was that it came with rockers, but it doesnt say they are roller or not. Also Im still wondering what type of headers they come with. Does anyone know what type of times I could run with this setup? Noone seems to be running this setup I guess. Any more input is appreciated.
Old Oct 30, 2002 | 03:44 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
I was thinkin of goin that route, after i totaled up the price, with other bolt-ons, it came close to what the want for the whole crate motor. Ill prolly bag lunch and save my penny's to go that way. After the crate motor, all you nee is a TB, runners, headers, and a chip. Plus you get a brand new motor with it.
Old Oct 30, 2002 | 06:22 PM
MrNova's Avatar
Can you tell me the prices and parts you were looking at? New heads and cam seem kinda far from a crate engine
Old Oct 30, 2002 | 11:22 PM
chevyboy07 91's Avatar
the rocker arms you speak of are NOT Roller rockers...they are stamped 1.5 ratio....just like your stockers
I am still waiting on my friggin manifold!!!!
Old Nov 3, 2002 | 04:52 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
if you do a heads and cam swap, unless you have a low mileage motor, the heads may increase you comp, and the seals will be better that the rest of the motor. Oil blow-by can be a problem. if you do heads cam and such, you may as well have the rest rebuilt while half of its apart. Put new bearings, overbore it, better than doin the work, having something else go, the tearing it all apart.
Old Nov 3, 2002 | 05:09 PM
mckenzie's Avatar
i already have the 88 L98 motor apart on the bench...i don't have anything to put it in. i may rebuild it with the vortec heads off the 98 350 vortec motor out of a 98 k1500 p/u...(vortec motor also on the bench) just wondering what kind of cam to go with. thanks, tom
Old Nov 5, 2002 | 03:31 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Hot cam would be a good one, but i would go with one of the LPE Hydraulic roller cams.
Old Nov 7, 2002 | 10:57 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
That seems odd that you are still waiting for your baseplate. They might be using them all for the crate engines. I ordered my crate engine and had it at my house a week and a half later.
Old Nov 7, 2002 | 07:19 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
first off im not tryin to hijack a post...this one was already made so i dont see the point in making a new one and wasting space on the server....
how will this vortec setup work on a 91 lb9...with and without the hot cam
thanks guys
Old Nov 13, 2002 | 05:02 PM
ericoo1's Avatar
Car: 89 silverado,02 s10 blazer
I ordered my basplate 2 weeks ago and got it yesterday. it was at the machine shop within an hour of me getting it, to be port matched to the heads I'm having done.
Fast355
Dec 2, 2016 06:33 PM
toronto formula
Nov 10, 2015 06:17 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
