Plenum question
Old Oct 30, 2002 | 02:06 PM
IROC_Canuck's Avatar
Plenum question
will an 86 plenum fit on a 90 TPI with SD?
Old Oct 30, 2002 | 07:40 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
can't see why it wouldn't. the runners will block the hole that would normally be for the ninth injector.
Old Oct 30, 2002 | 07:52 PM
bigals87z28's Avatar
Car: Check The Sig
the 86 will have the hole for the cold start injector... its the smaller hole under the 2 runners on the pass. rear side...
Old Nov 1, 2002 | 10:53 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
you can use a early TB and plenum on a later model but you can't use a later model with an early model.
MantyZ28
16
Dec 21, 2015 11:02 AM
Thaney9
Aug 29, 2015 03:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
redmaroz
Aug 16, 2015 11:40 PM
