fuel rail & injectors
Old Oct 30, 2002 | 03:28 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Once I remove the four bolts and disconnect the fuel lines from the fuel rail,do I just pull up on the fuel rail, injectors and all,and they come out of the base or do you disconnect the injectors first?After I took the bolts out I pulled on it a little and it did not come right off.I have to go to work anyway so I just stopped there until I find out.Thanks for any replies and if anyone has any advice or tips feel free to pass them on to me,I am removing the whole intake.Thanks again.
Old Oct 30, 2002 | 03:57 PM
Scott C's Avatar
Take your time and gently pull each end until it "pops" up out of the injector bores. It will come out, just be careful not to force it too much...also if you are taking off the entire intake, you can just leave the rail on the intake. I just pulled mine and I did it that way...very simple!
Old Oct 30, 2002 | 06:02 PM
kevinc's Avatar
Car: 1982 Z28
There's a 5th bolt on the front of the intake base holding the rails in place.
Old Oct 30, 2002 | 07:00 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Take note of what kevin said, a lot of newbies miss that one and you didn't mention it. And disconnect the battery first, you will be swinging a wrench right next to the hot post on the alternator while playing with fuel.
And if it's been on there forever, it will probably feel stuck. If you're careful there are places to pry on it if you look.
Old Oct 31, 2002 | 04:19 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I did see that other bolt,but didnt take it out I have also noticed that all the close up pictures here that you can see the injectors in,it just looks like the injector is sticking in the manifold base.On mine there is a round cylinder about an inch tall (it looks like it is aluminum)that each injector goes in,sticking out of the base.Could this be because it's a 90 and the others I am seeing are older?I have a picture I took with my digital camera,but when I try too show them in my post it tells me the file is too big,anyone know how I can post these pics?I also plan on sending the injectors off to cruisin performance to be cleaned and flow tested,what do you do about the wires?,or will I figure that out when I get the injectors off?Sorry about all the questions but I have never done this before and I know there are plenty here who have.I will be getting a Chiltons manual today,right now all I have is a Haynes,maybe it will be a little more help
Old Oct 31, 2002 | 11:13 AM
Morley's Avatar
Convert it to JPG, most any photo editing software can do it.
Old Oct 31, 2002 | 11:53 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
They come off of the little photo card as JPG already.
Old Oct 31, 2002 | 12:55 PM
Morley's Avatar
If it is a digital camera they should be in TIFF, which is a huge file compared to JPG
Anyway, Paintshop and a few other programs let you set the file size when you save a picture, might want to look at them.
Old Oct 31, 2002 | 12:59 PM
Scott C's Avatar
Not sure about those aluminum sleeves, but the electrical connectors to each injector simply unplug by pushing in the bent wire thing and pulling the connector up and away from the injector.
Once you have removed the fuel rail, then you have to remove the injector "clip" from each injector to remove it from the rail. The clip is at the top of the injector and slips into the rail. You need a small flat head screw driver to slide the clip to the "unlocked" position and then the injector can be removed from the rail. Unlocking the clip can be frustrating. Just take your time and don't force it...good luck!
Rich at Cruzin' Perfomance is the Man when it comes to injector cleaning and flow matching. He can also help answer any questions you may have. He's a great Guy!!
Old Oct 31, 2002 | 03:52 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Test
Old Oct 31, 2002 | 03:54 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Finally got a picture up. Those things under the injectors are what i'm talking about.
Old Oct 31, 2002 | 05:27 PM
kevinc's Avatar
Car: 1982 Z28
Uh, there's nothing under the injectors but the intake base.
Old Oct 31, 2002 | 05:48 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Thats just the injector body late 80s-92 used that type of injector.
Old Nov 1, 2002 | 02:37 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I figured they were the injectors,but like I said they just look different than most I have seen on here and in the repair manuals . Thanks for all the info everyone.
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
