Are 95 LT1 Caprice injectors 24#?
Old Nov 4, 2002 | 11:05 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I was wondering anyone knew if 95 LT1 Caprices came with 24# injectors?
Old Nov 4, 2002 | 11:19 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
They should be.... the LT1 called for 24# injectors to feed it properly.... so the caprice shouldn't be any different. Only thing different in a CAprice LT1 vs an F-Body LT1 vs. Y-Body LT1 should be exhaust and the mounting of the accessories (alternator, etc).
Old Nov 5, 2002 | 05:42 AM
S10Wildside's Avatar
To the best of my knowledge all LT1s got 24lb injectors. The 4.3 V8 with "LT1" intake uses different injectors.
Old Nov 5, 2002 | 01:12 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The Caprice LT1 is the baby LT1. It may come with 22's.
Old Nov 5, 2002 | 01:46 PM
No, I don't believe the Caprice LT1 is the "baby" LT1 just because it's not in a Camaro/Firebird/Corvette. The 4.3 V8 is a "baby" LT1, but the 5.7 in the Caprice/Impala/Roadmaster/etc is not necessarily a baby LT1.
Old Nov 5, 2002 | 02:41 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
An LT1 is an LT1 is an LT1.
The only difference, as previously stated, is the exhaust and the places in which the accessories mount.
Old Nov 5, 2002 | 03:44 PM
True, but the intake on the 5.7 LT1 motor is also used on the 4.3 V8 Caprice motor. The intake is absolutely exactly the same except for the injectors.
Old Nov 5, 2002 | 04:55 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
It is a 5.7L LT1. So I assume they are 24# injectors then.
Old Nov 5, 2002 | 05:13 PM
you could always have them flow tested (and cleaned while you're at it)
if i were in your shoes, i'd make the assumption they were 24lb/hr
Old Nov 5, 2002 | 06:28 PM
trigger GTA's Avatar
Car: 92 TA vert
and also the heads are iron and not aluminum
Old Nov 6, 2002 | 01:14 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
the cam is also slightly different in the caprice LT1 and the corvette LT1 but they all have 24# injectors...
New2Chevy
Sep 28, 2015 12:35 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Strick1
Sep 6, 2015 10:38 AM
L0tuS
Sep 4, 2015 11:16 PM
