Do AFR 190 heads come predrilled for temp sensor and egr?
Old Nov 5, 2002 | 10:13 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I've heard that AFR 190s need to be drilled for the temp sensor and EGR. Is that true?
Old Nov 5, 2002 | 10:46 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Mine had to be drilled for EGR but not sure about the temp sensor. I *believe* you can request that be done for you when ordering. It may depend on who you're getting them from though.
Danny T
Old Nov 6, 2002 | 08:02 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You have to tell them to drill for the temp sensor, which is around $40 extra.
Old Nov 6, 2002 | 02:08 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
I ordered my heads from Total Engine Airflow in KY. That's the cheapest place I found them. I think it was only $25 there to get the sensor holes tapped. Ask for Brian, he's a great guy.
Old Nov 7, 2002 | 06:48 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Is there anything else I need to know other than the EGR and Temp sensor? As far as other holes being drilled?
Old Nov 9, 2002 | 11:34 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I'm not sure what kind of engine you are using these on but I would have them milled to 64cc if you want to keep stock compression ratio. They come w/68cc chambers so if you put them on an L98 you will drop a few points of compression.
I had mine milled to 64cc so on a ZZ4, I'm making 9.6:1.
Old Nov 9, 2002 | 09:27 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Yeah thats what I planned on doing. By the way they are going on an L98.
Old Nov 10, 2002 | 02:29 AM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
If so, than I would suggest having them milled down to 60cc. This way you would have a L98 Corvette-like CR.
I got mine from, Tenacious Performance, for $1450 shipped w/temp sensor drilling, heat risers and milling.
Old Nov 10, 2002 | 06:23 AM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
They have a website or number?
Old Nov 10, 2002 | 08:57 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I think it's www.tenperf.com. Hope that helps.
Old Nov 10, 2002 | 09:15 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
n/m
mdtoren
Aug 23, 2015 12:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
