How do I determine what size fuel injector I have?
Old Nov 10, 2002 | 06:02 PM
337's Avatar
337
As some of you may know, I recently got a good deal on an '86 Trans-am. Now, the previous owner insisted it was a 305 converted to a 350 TPI, but I'm not so sure.
How would I identify what rating fuel injectors I have? I know Fords do it by colors, does GM do it the same way? If so, what colors correspond to which size injector?
Old Nov 10, 2002 | 08:27 PM
Z28DJP1987's Avatar
You can not convert a 305 to a 350 (His BS). All stock 305's have 19# FI. To my knowledge, GM did not color code them.
Old Nov 10, 2002 | 11:09 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
maybe an engine swap is what the guy spoke of? the only way to be sure it is a 350, is to get the block casting# and a head casting #. as stated all 305's come with 19lbs injectors. get the part # off an injector and post it here. some one can chime in with the answer.
Old Nov 11, 2002 | 08:16 AM
Z28DJP1987's Avatar
I still see the words " insisted a 305 converted (BS) to a 350". Not swapped to a 350, need more info on what the seller's did
(BS).
Old Nov 11, 2002 | 09:06 AM
Car: 1988 IROC-Z
people mistakingly use the word converted for the word swapped. i don't know why? i too call bs unless he get's some casting #'s. people like to say yeah it was "converted" to a 350 to sell it for a little more. yet a 305 still lays in between the fenderwells.
Old Nov 11, 2002 | 02:00 PM
337's Avatar
337
Sorry, I meant to write "swaped for" and not "converted". I know originally it was a TBI from the vacuum diagram on the hood and by putting the VIN on the carfax website. I'm sorry I just got a little confused.
The injector ID # is 5235047 (taken off the top ledge of the injector itself) If anybody knows what size this is, please post.
Since I know something has been changed, I'm trying to findout what it was changed to.
Thanks....Sorry about the mix-up up there.
Old Nov 11, 2002 | 02:11 PM
Z28DJP1987's Avatar
Well, IF it was swapped to a 350 you are running the following.
1985, 305, A/C Delco, 19# FI which is your #523507 and the GM
P/N 17110872, also they were made by Lucas. I still think the seller was giving you (BS).
Car: 1988 IROC-Z
hey man no prob we all make little mistakes at times. as for the injectors they are 19# injectors
Year CID Mfg. OE Part #
1985 305 AC 5235047
Edit: oops Z be me too it. oh well . heheh
Old Nov 11, 2002 | 02:18 PM
337's Avatar
337
Thanks guys, I appreciate it!
Old Nov 12, 2002 | 02:11 PM
Guest
Guest
Posts: n/a
Just FYI, an 86 wasnt available TBI, only carbed or TPI.
bryan623
Mar 22, 2021 06:43 PM
toronto formula
Nov 10, 2015 06:17 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
