Porting L98 Iron Heads
Old Nov 11, 2002 | 06:46 PM
S10Wildside's Avatar
I have two concerns about porting stock 1987 L98 Iron heads.
Are they more prone to cracking? (They'd be professionally ported)
Are any modifications necessary to install the LT4 HOT cam kit with L98 Iron heads? I really don't know the difference with heads that require self-aligning/non-self-aligning rockers, harndened guideplates, etc, etc.
Old Nov 11, 2002 | 07:54 PM
Bort62's Avatar
To Safely Use the Lt4 HOT cam, you should have the Valve Guides Cut Down to accomodate the .525" lift.
Additionally, Might as well have the Spring pockets cut To use the larger OD springs instead of the Cheapo Lt4 Springs.
Old Nov 12, 2002 | 02:19 PM
Guest
Guest
Posts: n/a
More prone to cracking as opposed to what? Unported heads? Unlikely. Most heads either crack the valve seat, or iron L98 heads like to crack the spot between the spark plug and water passage.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
beastin91rs
Oct 9, 2015 07:38 AM
