correct me if i am wrong
Old Nov 11, 2002 | 05:57 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
ok if the temp and knock sensor where un pluged i should get a ses light. the two sensors on the pass side of my motor are unpluged one in the head the other in the block. the car is a 87 with a l98 in it. am i right thinking the one in the head is the temp and the one in the block is the knock. i would plug them back in but the goober that had the car befor me broke the clips where can i get new fittings
Old Nov 11, 2002 | 07:45 PM
89BlueTA's Avatar
You would not get an SES light for having the knock sensor unplugged on an 87, I am not sure about the temp sensor.
nick
Old Nov 11, 2002 | 07:50 PM
Bort62's Avatar
Junkyard.
Old Nov 11, 2002 | 09:35 PM
c4boom's Avatar
Engine: l98 and lo5
bummer no f bodys in yards around hear what other cars use the the same clips
Old Nov 11, 2002 | 10:11 PM
MdFormula350's Avatar
the fan switch is the one way up further back on the engine and higher up and has the one wire going to it..
the knock sensor is the closest one and lower in the block..
Old Nov 11, 2002 | 10:14 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Don't quote me but, I think you can get (new) replacement connectors in the 'Help' section, or order them from the catalog, of most major part store chains
Old Nov 12, 2002 | 02:40 PM
Guest
Guest
Posts: n/a
You can order new 'clips' from any decent parts store. I just got one a couple weeks ago.
Old Nov 13, 2002 | 03:00 PM
c4boom's Avatar
Engine: l98 and lo5
thank you i will have to make some calls i dont like running with things not hooked up. and one last question dose any one know where there is a online wiring diagram
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
