Stalling problem
Old Nov 14, 2002 | 06:59 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Stalling problem
ok let's see if you guys can help me out with this. The car is an 88 IROC. 350 TPI, mods: S/R heads, edelbrock headers, catback, T-56 and Superram. I can make the car stall everytime if I do this:
Drive with it in 1st gear bring the RPM's up to 2K then let off the gas and let the car slow down a bit then push in the clutch. it will drop down to 500 RPM's and stall everytime. any ideas?
Old Nov 14, 2002 | 09:53 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Have you checked and cleaned your IAC? Mine did the same thing until I cleaned the it. (Idle Air Control)
Old Nov 15, 2002 | 04:02 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Yeah like a million times. After more research I found it only does it in closed loop.
Old Nov 15, 2002 | 06:48 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
sounds like a vacuum leak, my Formula (87) did the same thing and i figured out it was a blown intake manifold gasket...
good luck
Josh
Old Nov 16, 2002 | 03:36 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I was hoping against that but now that I think about it, it started after the Superram was put on.
What is the best way to check for vacuum leaks?
Old Nov 16, 2002 | 03:54 PM
ok, get ya a can of starter fluid, fire up the car, and slowly spray around the base of the intake. if the car suddenly revs up then there's your vacuum leak...
good luck
Josh
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
