TPI Intake question
Old Nov 15, 2002 | 06:13 PM
mich2112's Avatar
Car: 1991 Z28
Engine: 350 L98
Axle/Gears: G92 - 3.23
TPI Intake question
I have an 88 Iroc with a 305 TPI. I plan on installing a L98 motor from 87 or newer IROC or a 350 4 bolt main from a heavy duty van (from a 87 or newer). Both motors have the 1 piece seal. My question is about the intake - I hear that the center intake bolts are at 72 degree angle on the 87-92 L98, but what about other 350's from the same era?
Is the center bolt heads the clue to the 72 degree angle?
The van motor has center bolt heads as well.
Here are the block and head numbers from the van motor?
Block: 14093638...350...87-95...2 or 4 bolt main...Roller or flat tappet cam one-piece rear seal.
Heads: 14102191...1986-88...350 1.94 1.5001 - EFI, swirl port
Is my 305 TPI intake the 72 degree type?
Thanks, Mike Jones
Old Nov 15, 2002 | 06:35 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
it will work
Old Nov 15, 2002 | 07:50 PM
Bort62's Avatar
Yeah, All 87+ Non Vortec SBC heads will work fine w/ the TPI intake.
Well, except the Corvette L98 heads.
Those are on the pre 87 boltpattern.
Old Nov 15, 2002 | 10:17 PM
bigals87z28's Avatar
Car: Check The Sig
wait... the corvette heads wont fit! umm dont mean to flame.. but y not? they have the same bolt pattern as the camaros... and the aluminum ones are killer.... thats gunna be one of my mods that are coming soon.. maybe next summer... oh boy oh boy... cant wait... and maybe a nice cam that wont make the computer flip out...
Old Nov 16, 2002 | 02:24 AM
Bort62's Avatar
The aluminum L98 heads use the old style bolt pattern. They won fit a Camaro TPI w/o modification.
the Modification is trivial, however.
Old Nov 16, 2002 | 11:45 AM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
Trivial exactly. If you aren't a moron and you have a die-grinder or a really good drill you can make the intake work with. It's easy... I did it
Hodge
1992rs/ss
Jan 31, 2025 05:10 PM
masonta
Aug 31, 2015 10:14 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
Sanjay
Aug 12, 2015 03:41 PM
