engine miss?
Old Nov 16, 2002 | 11:41 AM
87GTA Runner's Avatar
Car: 87 GTA
engine miss?
Can anyone help me? My 87 GTA with 5.7L TPI has a miss. It idles OK, but when I give it even the slightest throttle it misses and feels like it is going to stall. It misses from idle to about 1500-2000 RPM, where it seems to clear up. The problem gets worse when the engine warms up. It has already stalled a couple times when giving it throttle when backing up in reverse. I have Edelbrock TES headers, chip and a thermostat already installed. I am waiting to fix the problem until I put the SLP runners, cold air kit and ported intake/plenum on that I have. By the way, the miss was already there before I started doing any modifications. Has anyone had a problem like this that can help me out?
Old Nov 16, 2002 | 12:59 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
You should start with a tune up. If that doesn't help then you need to start testing your ignition system. It'd also be a good idea to ohm out your injectors. Are you getting any codes?
Old Nov 16, 2002 | 02:23 PM
Car: 87 GTA
I already installed new AC plugs, AC cap & rotor and Taylor wires. It is not showing any codes. I was thinking either injectors or some kind of sensor might be the problem.
Old Nov 16, 2002 | 11:21 PM
88TAJeff's Avatar
Car: 88 T/A
First off, do you have a timing light? this way you could confirm whether it's really a 'miss' or not. Make sure you check each cyl. with it as well. Welcome BTW!
Good luck.
Old Nov 17, 2002 | 01:19 AM
MdFormula350's Avatar
a timing check would be a good idea..
Old Nov 17, 2002 | 06:56 AM
Car: 87 GTA
Thanks, guys. I haven't checked the timing. I'll get on that and let you know what happens next.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
