Need Help With Cam
Old Nov 17, 2002 | 08:51 AM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
Need Help With Cam
I have an 89 formula with 305 tpi looking for the biggest cam or the best cam i can use with stock heads. My mods are headers, dual flowmasters, no cats, chip,k&n,free mods. I have center bolt valve covers do I have a hydraulic roller cam. what is the max lift on my stock heads??
Old Nov 18, 2002 | 04:14 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
anyone?
Old Nov 18, 2002 | 06:26 PM
rockind78's Avatar
Call a major cam manufacturer of your choice, and ask for advice as to what cam you should have. They are usually pretty good. I have a buddy who worked for Comp, and he was pretty confident about their facilities (sales, tech, products, etc.). Also, if your car has not been messed with, then it has a roller cam. I would guess the max stock lift on your heads is .500 ( but I am not certain of that. Remember....bigger is not always better.
Old Nov 19, 2002 | 11:55 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I'm in the same boat, looking for the right cam. At this point I like the Crane 2032 P/N 104224, the durations are right but I'd like just a touch more lift, so I think I'll get a custom grind. I hear the max lift on stock heads is 500, but I'd say that's pushing it so I'll stay at 480, slightly less on the intake.
Old Nov 22, 2002 | 08:27 PM
Shagwell's Avatar
Car: projects.......
I would call someone like Comp. Recomending cams is what they're sales personel do for a living. As for how big you can go, I would recomend airing up the cylinders and replacing the springs. you can get the GM LT1 Z28 springs(rated easily to .510 lift) w/ retainers and locks for $29.95 from CP. (Competition Products) - just a cheap insurance policy to go w/ a new cam. -
later, justin...
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
