Unhook EGR?
Old Nov 26, 2002 | 02:33 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Unhook EGR?
I am trying to start my car tomorrow, with alot of motor upgrades. I cannot find the small line that goes from the EGR to that little piece on the back of the manifold. What would happen if I started the car without this hooked up? I am not exactly sure what an EGR does either, maybe somebody can help me out there too. Thanx guys.
Old Nov 26, 2002 | 02:40 PM
rezinn's Avatar
Just plug both of them for now, otherwise your car will run like crap.
Old Nov 26, 2002 | 02:44 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
You can get vaccuum terminators at any local autoparts store in the HELP section. Just throw those on there to prevent vaccuum leaks.
Hodge
Old Nov 28, 2002 | 11:30 PM
canadiangta's Avatar
I ripped the egr right out of my 88 gta tpi, and it runs better. the egr takes air pressure from your smog pump on the fanbelt and pumps the air into your manifolds and cat. egr means emission gas recirculation. i removed the cat, air lines, smog pump and egr with no problems.
Old Dec 1, 2002 | 05:48 PM
89Formula350WS6's Avatar
I was just about to post a question about this myself.
So I can delete my EGR and it won't affect my performance, driveability, economy, or throw off a check engine light???
This is good news!!
Old Dec 1, 2002 | 09:00 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I'm pretty sure it will throw a code but it's not an important sensor so the car will run the same. You'll need to keep it if you have to smog though.
Old Dec 1, 2002 | 10:05 PM
Falcon3's Avatar
Go to technical articles on this site and look under an article name "The Lowdown on Code 32" It'll tell you everything
Old Dec 2, 2002 | 01:03 AM
360Iroc's Avatar
this will not throw a code, at least it didnt for me
Old Dec 3, 2002 | 04:12 PM
jonarotz's Avatar
Car: 91 Z28
I know that this is an old posting but some things should be said correctly about the EGR valve, first it stands for Exhaust Gas Recilculation, Second it controls the NOX (Emissions gas tested for in some states). It cools down combustion chamber temps by introducing spent exhaust into the intake charge. If you look at your intake you will notice that there is an EGR passage that ties right into an exhaust passage. The EGR valve can vary the amount of exhaust gas according to engine vacuum or an electronically controled solenoid. You can get away with unhooking it but it might throw an occasional code. From experience I have noticed no significant gain in removing it . I am not trying to trash anyone for not knowing what it does, but I have heard a lot of misconceptions about it and am just trying to clear it up.
Old Dec 3, 2002 | 07:08 PM
AlexJH's Avatar
Engine: 5.7L V8
If you are going to remove your EGR system, you should burn a new PROM so the ECM knows that it's not there. Otherwise the ECM will advance the timing thinking that the EGR is cooling the combustion chambers... but you aren't, so you will probably see some knock.
How do I know? It happened to me.
Old Dec 3, 2002 | 09:15 PM
Thanks for the replies. Sounds to me like there's nothing to gain by deleteing it.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
