injecter size
Old Nov 27, 2002 | 05:16 PM
deviousstylz's Avatar
injecter size
Alright new here need a little help. What injecter size do yall think would be best for my 87 irocz so far I have rebuilt the 350 bored 60 over with a lunati cam 224 deg dur and 460 lift on intake and exaust with corvette alumanum l98 heads compreshion is around 9.5 I got the edelbrock tpi intake with slp runners ported and polished plenem and a bbk 58mm throttle body and bbk fuel pressur regulater set at 50 psi this car is stout but I know I can get alot more out of it .
Old Nov 27, 2002 | 06:22 PM
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
you have no need for larger than stock 350 injectors, if it needs more fuel just up the fuel pressure, unless you have a programable computer, you would end up running too rich with say a 30# injector. why do you ask? stoichiometric is the most efficient way to power, more rich will slow you down....
Old Nov 27, 2002 | 11:28 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
24# will work fine with this setup, you'll need to start burning your own PROMs to get the most out of it.
Old Nov 28, 2002 | 11:18 AM
why do you ask? stoichiometric is the most efficient way to power, more rich will slow you down.... Well its a little lean at idle like at stop lights
Old Nov 28, 2002 | 06:15 PM
gflo383's Avatar
Car: IROC Z
what i meant was, if its runnin close enough to stoich, why would you want larger injectors, you wont gain hp from them...
PurelyPMD
May 5, 2016 04:57 PM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
mackjar66
Sep 14, 2015 01:17 PM
m00n420
Sep 11, 2015 02:39 PM
