want to convert 305 tpi system to 350
Old Nov 28, 2002 | 12:03 AM
87iroc305tpi's Avatar
i got an 87 iroc with a 305 tpi i want to get a brand new 350 motor, i was wondering what i would have to do to put a 305 tpi system into a 350 motor that was designed for using a carb.and one more thing, when i was searching for motors it said
"foruse up to 1985" could some explain to me what that means. thanks alot
Old Nov 28, 2002 | 02:28 AM
Guest
Guest
Posts: n/a
305 and 350 TPI parts (intake) are all the same deal. The injectors, knock sensor, and chip in the ecm are different. Not real hard to 'convert' from one to the other.
Old Nov 28, 2002 | 08:40 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The ESC is different as well, although I doubt its effect is substantial.
Old Nov 28, 2002 | 12:12 PM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
I think that the "for use up to 1985" refers to the main seals. Is that right? That 350 probably has a two piece seal instead of a one piece.
Old Nov 28, 2002 | 04:16 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
be sure to check the heads to make sure your intake will go on there properly. the pre-86 heads are different on the center intake bolt angles. You will have to have your intake slotted i believe to put them on the older heads if they are the older heads. If not, there will be no problems. Also besure to check if the motor is a 2 piece rear main seal or a 1 piece rear main seal.
jaridjohn
Jul 8, 2024 03:49 PM
beachrodder
Aug 25, 2015 08:05 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
