TPI Plenum ?
Old Nov 28, 2002 | 01:09 AM
zerotosixtyV8's Avatar
Car: Camaro
TPI Plenum ?
would a ported plenum with a 52mm TB provide enough airflow for a mild 383? Peak power comes at 5500 rpm on this motor, but I am wondering if what I've got done is enough, or if there are mods I can do (that don't include buying a stealth, super, or mini ram intake) to help it out a bit top end for this motor?
Old Nov 28, 2002 | 02:24 AM
Guest
Guest
Posts: n/a
The plenum and TB really are the least of your worries. The base and runners are much more of an issue to deal with.
Old Nov 29, 2002 | 05:45 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Word.
On a 383 I would as far to say that a fully ported TPI plenum and base with aftermarket runners would just barely get you by.
I think you ought to reconsider the Stealthram/Mini/LT1!
The stock TPI is just not cutting it modified or not.
BTW - an aftermarket TB* cost almost as much as a full Stealthram setup =)
*and is NOT going to help either!
Old Nov 29, 2002 | 07:58 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
A good set of runners and/or an aftermarket intake manifold would help
Old Jan 9, 2006 | 02:48 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
have you considered the aftermarket TPI manifold base's available (e.g. Edelbrock, TPIS, etc)? the manifold ports are much bigger than stock, and would mate well with aftermarket runners (e.g. SLP) and your ported plenum.
but this is nothing new, recognizing this is an old thread.
MantyZ28
16
Dec 21, 2015 11:02 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
Sanjay
Aug 12, 2015 03:41 PM
