Can someone help me with pulley questions?? Please??
Old Nov 28, 2002 | 12:15 PM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
I want some underdrive pullleys. My question is which ones do I get? The three piece set or the two piece set, or the power (voltage) saver set?
Old Nov 28, 2002 | 12:41 PM
89BlueTA's Avatar
First off everyone on here is going to tell you not to get them.
I personally like mine, the two piece set will give you more underdrive than the three piece set, thats the one i would suggest.
nick
Old Nov 28, 2002 | 12:55 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I had charging problems with the 3-piece set so I removed the March alternator pulley and put the stock one back on.
Old Nov 28, 2002 | 02:13 PM
jd13's Avatar
I say go for them. Two peice set though. I also had to remove my altenator pulley after going through quite a few altenators. I also have a decent stereo so that attributed to that fact. I definatly think they are worth it.
Old Nov 28, 2002 | 07:24 PM
firebirdkid's Avatar
why would anyone tell him not to get them?
Old Nov 30, 2002 | 08:49 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I run the 3 part set no problems here. One thing I dont like it the way i cant put the nut on all the way on my alternator. Anyone else have this problem?
Old Nov 30, 2002 | 09:09 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The question you have to ask yourself is: Is 0.1 to 0.15 max gain worth potentially killing batteries and alternators on a regular basis from the lack of charging. Don't forget you could potentially get stranded if you do any real traveling because of this. If you do a lot of idling and low RPM driving especially things could get ugly.
Old Nov 30, 2002 | 11:37 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Good point Ed. If you do around town cruising you will probably have trouble. If it's used more for highway/racing then you'll have no trouble.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 12, 2015 11:33 AM
