Superram and change injectors.
Old Dec 8, 2002 | 07:24 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi...
Is it possible to change injectors without removing the superram plenum?
any tips or hints?
/N.
Old Dec 8, 2002 | 09:54 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
No, at least i've never heard of it. Even if it was doable, it would still probably be just as much of a pita as just popping the plenum.
Old Dec 8, 2002 | 02:42 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Eds' right. Absolutely no way. You have to take the fuel rail off in order to remove the injectors. Can't take the fuel rail off with out removing that big *** plenum.
Old Dec 8, 2002 | 09:21 PM
Ragtop89's Avatar
I concur. You have some work ahead of you.
Old Dec 8, 2002 | 09:25 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Sorry guy, plenum has to come off. Yank the plenum and then split the fuel rail in half by unscrewing the torx bolts holding the crossover tubes in place. This will at least let you remove and install the fuel rails without having to remove the runners.
Oh and when you go to put the fuel rails back together coat the o-rings with oil so that it'll slide together easy.
Old Dec 9, 2002 | 12:14 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I suspected that......Car is in a winter storage now, probalby need some more tools and a picnic bag with me
Thanks guys!
/N.
Hellbillydeluxe
Sep 22, 2015 09:58 PM
1fast91
Sep 8, 2015 01:48 PM
db057
Sep 4, 2015 07:57 AM
hydrolic144
Aug 29, 2015 04:14 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
