Here I go again..... Now it's a voltage problem in my 87 IROC.......
Old Dec 9, 2002 | 06:31 AM
tazmision89's Avatar
The episode of the neutral switch is over but now when I am driving my car and I get to a light, the voltage meter jumps from 14 to 9 to 14 to 9 and then stays at nine till I throw the car in neutral and give it gas. BTW, it does the samething even in neutral when I don't give it gas.
Lights dim inside and outside the car. Never had this problem at all. What do you guys think it is?
Thanks.
Old Dec 9, 2002 | 10:10 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
So what was the question?
Do you have underdrive pullies? If so, no surprise, of course it doesn't charge worth a damn at idle.
Otherwise, unless you've recently added some high draw accessories, and unless you have a loose/bad wire/connection, i'd say your alternator on it's way out. No surprise there, the alternators that came in our cars are complete junk and die all the time.
You can upgrade to a CS-144 series alternator like came on the B4C cars. It's a large case high output design and is not prone to oveheating like the stock CS-130. Do a search on CS-144 swap or variants to find info in this, you'll need at leasta new alt. bracket to handle the bigger case, i forget if there is anything else. You also *may* be able to swap a CS-130D in, which is the later model open case 130 design that also cools much better, but i don't know if there is anything useful out there on this swap. Or just replace it with a stocker and cross your fingers.
Old Dec 9, 2002 | 11:41 AM
thanks for the info!!!
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
