biggest cam i can run...help!
Old Dec 16, 2002 | 10:34 PM
5L EaTeR's Avatar
just wondering about cam selection:
i have the Accel Super Ram setup with sportsman II iron heads mildly ported/polished (unfortunately theyve never been flow-tested), 58mm TB, etc. i am switching over to a solid roller setup this winter and i know the super ram setup works best with an agressive cam. im getting beefed up valvesprings, 1.6 rockers, etc. but was curious on cam specs as i dont want to 'over cam' yet i want to go as big as possible.
its gonna be a custom grind: what are some rough specs i should be looking at? im thinking around .550 lift @ .50 112 lsa, duration im not sure on though.
can anyone offer any advice/suggestions?
Old Dec 17, 2002 | 01:05 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I dont know what the i/e ratio on your heads are, but if it is good I'd look at a single pattern with the SR. I am soon switching to a 224/224, .560 .560 (1.6rr), 110 lsa.
I have seen some big duration solid roller cams used with the SR with good results, Like 230ish or more.
Old Dec 17, 2002 | 09:48 AM
Vader's Avatar
Re: biggest cam i can run...help!
www.compcams.com / 1-800-999-0853
...i dont want to 'over cam' yet i want to go as big as possible.
(See above) In my opinion, they tend to be a little on the conservative side with their cam profile selections and recommendations.
Old Dec 17, 2002 | 05:59 PM
5L EaTeR's Avatar
i called the comp cams hotline already and the cam they recommended was VERY mild. it was a chick i was talkin to though, so....
i thought 110 lsa might be a little low...i guess i could borrow hook up a vacuum gauge, but can anyone tell me off the top of their head how much vacuum the SR plenum makes?
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
