Stealth Ram wiring harness
Old Dec 17, 2002 | 10:10 PM
The00night's Avatar
Has anybody used the wiring harness and ECU that comes with the Stealth Ram? I was wanting some feed back positive or negative.
Old Dec 18, 2002 | 12:19 AM
rockind78's Avatar
To my knowledge, most of the guys in here running the Stealth Ram are using their factory harness and ECM's. If you are referring to the Holley Commander 950 setup, I am sure Doug would be willing to answer any questions you may have over in the EFI forum at
www.chevytalk.com
Old Dec 18, 2002 | 01:06 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Yes, I had great luck using my stock wiring and 7730 speed density TPI setup. Not much at all had to be modified for everything to work fine. It is definetly a cheaper route and much easier to "plug and play" (with the exception of extensive chip work courtesy of Ed Wright). I do plan on playing with DFI too someday, and I have heard good things about the holley version from other non-thirdgen sites.
9192camaro
16
Feb 3, 2019 12:21 AM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
stalkier
Aug 21, 2015 01:54 AM
L98GTA87
Aug 11, 2015 06:55 PM
