Vette intake?
Old Dec 18, 2002 | 05:41 AM
likeistoleit's Avatar
Car: 87 Iroc
Transmission: Tremec Tko
Vette intake?
I am putting together a motor for an 86 vette, looking at either a miniram or a stealth ram. The cost is beginning to become an issue. I would like to know if anyone has knowledge or opinions on the performance of both. One other issue is hood clearance, will it fit under the vette hood? I will be running a set of AFR 195s and maybe a zz-9, although I would like a cam that is a little larger.
Old Dec 18, 2002 | 07:38 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
cost is an issue?
www.lt1intake.com
Old Dec 18, 2002 | 02:32 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Re: Vette intake?
No.
You will either have to cut the hood and raise the mid-section some, or have the intake cut down. Personally I would rather cut the hood as holley designed that plenum volume for a reason and I would not want to screw with it.
Old Dec 18, 2002 | 02:42 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Dec 18, 2002 | 02:45 PM
scorp508's Avatar
Car: Corvettes
Originally posted by QwkTrip
.... and a job???
What is this "job" you speak of? I'm actually at work now, but its slow as hell.
Old Dec 18, 2002 | 06:55 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Somebody on this board cut down the stealth ram to fit under a firebird hood. He had the fins milled off the top, and only had to cut down the runners by about 1/16". On the vette, you need almost an inch of extra space though, so it might not be that easy.
Old Dec 19, 2002 | 05:33 AM
Car: 87 Iroc
I guess I will be spending the money for the mini then. Any cam recommendations. I am looking for a mid 12 combo with AFR 195s, mini and full exhaust.
tomclf
Mar 24, 2010 10:21 AM
stalin05
Aftermarket Product Review
Aug 22, 2004 11:30 AM
pasky
Feb 5, 2004 11:24 PM
Skipit
Sep 21, 2002 07:11 PM
spartyon
May 10, 2002 06:48 PM
