polishing TPI
Old Dec 18, 2002 | 03:34 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
polishing TPI
well, i already polished my plenum- that was easy
how do i go about polishing the hard to reach areas of the other components (TB, runners, manifold itself) are the sanding drums/rolls i can purchase?
Old Dec 18, 2002 | 03:41 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I don't suggest trying to polish the Base itself. It is barely seen, and a nice clean job and some nice paint and that is all I would do. As for the runners I would get a dremel with the nice small buffing attatchment to get into those hard to reach spaces. Be carefull though you can burn marks into the metal if you use to much pressure. Let the tool do all the work. I have never personnally polished one of these types of plenums but I have polished alot of Harley parts and stuff. All turned out great.
Old Dec 18, 2002 | 03:57 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Re: polishing TPI
I would recommend www.eastwoodcompany.com they have all the stuff you would need. (tapered sanding drumms, buffs etc) I would also recommend a air die grinder they cost about $20, of course that is if you have a compressor, but work much faster than a dremmel. I polished my manifold base, and I enjoyed doing it. However kaz is correct, you will not see alot of it once it is assembled, but I said what the heck and did it any way.
86IROC112
Sep 29, 2015 04:07 PM
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
