Stealthram and AFR's one Q
Old Dec 25, 2002 | 01:08 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Will the stealth ram bolt up with the afr 195's or do i need to elongate the holes, like i did with the TPI to make it fit ? I thought i heard somthing about them make two versions with diffrent bolt angles ?
Oh and when i order the fuel rail kit ill just need the basic one if i already have an AFPR right ?
Old Dec 25, 2002 | 01:49 PM
xanax's Avatar
my stealth ram from summit came double drilled for both bolt patterns. also a TPI fuel regulator will not work with the stealth ram fuel rails. you have to get the rails with an adjustable regulator if you want to mess with fuel pressure
Old Dec 25, 2002 | 02:09 PM
91Z28's Avatar
Car: 91' Z28
ok since i cant use my AFPR, do you think i should get holley's ? or will i be okay without since i will have the FMU for the D1SC ? and 32# injectors ?
thanks in advance !
ULTM8Z
Oct 2, 2015 01:25 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
tuningnewb
Sep 23, 2015 07:06 PM
355tpipickup
Sep 13, 2015 11:35 PM
