Stock coil location
Old Dec 28, 2002 | 10:59 PM
91_350TPI's Avatar
Car: Lucky Dog Racing 1992 Chevrolet Camaro Z-28
Engine: 379 cid Chevrolet race engine
Transmission: Coam TH-350 w/ transbrake
Stock coil location
Does the stock coil on my GTA mount on the fire wall or is there a bracket that mounts on the intake? Thanks in advance for the tips. Drive on...........
Damien
Old Dec 28, 2002 | 11:23 PM
rezinn's Avatar
If it's like my car was, it connects to the egr solenoid near the distributor hold down bolt on the side of the intake, which connect to the intake. If you don't have an egr solenoid, well..then like me it just floats around there somewhere
Old Dec 30, 2002 | 02:33 AM
Odyssey's Avatar
All FBodies with a remote mount coil will use a bracket that's mounted to the manifold using the last two bolts on the passanger side.
Old Dec 30, 2002 | 08:37 AM
Jza's Avatar
Jza
All TPI f-bodies with the remote coil...
Old Dec 31, 2002 | 12:02 AM
MdFormula350's Avatar
thanks for clearing that up
Old Dec 31, 2002 | 12:30 AM
Odyssey's Avatar
TPI, TBI and carbed use the same setup. Why do you think only TPI's are mounted that way ???
Old Dec 31, 2002 | 08:17 AM
Jza's Avatar
Jza
TBI remote coils are mounted to a seperate mount cast into the manifold. It locates the coil directly between the TBI and the distributor and slightly to the driver's side.
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 25, 2015 07:34 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
Thirim
Aug 13, 2015 03:09 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
