which headers?
Old Dec 29, 2002 | 07:26 PM
AXMAN's Avatar
which headers?
Here's what I'm dealing with: 2.5" madrel bent pipes, flowmaster 80 series muffler. But basically it's the same format as stock. The headers are stock and I fear they may suck. So which headers do I get? I'm looking for whatever will give me more hp and torque, as usual. Which company? where do i get them? how much do they cost? Thanks so much.
~Alex
Old Dec 29, 2002 | 10:18 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hmmn.,would have thought you'd had a dozen replies by now...
For longevity, SS is a must...and as far as I know, the only SS headers out there for our cars are by SLP...they come both in "off Road" or "50-state" legal.
For the 305, 1-5/8th are recommended.
Maybe you should take a trip to the exhaust board...for all I know, they have full length headers that are legal now.
Old Dec 30, 2002 | 12:21 AM
AXMAN's Avatar
thanks for the help and the support, i'll check those out
Old Dec 30, 2002 | 12:27 AM
MdFormula350's Avatar
Headers, 1 5/8" 1982-92 Camaro/Firebird 1 Cat w/A.I.R.
http://www.slponline.com/view_produc...RTNUMBER=30000
Headers, 1 5/8" 1982-92 Camaro/Firebird 2 Cat w/A.I.R.
http://www.slponline.com/view_produc...RTNUMBER=30002
also Hooker makes some
https://www.jegs.com/cgi-bin/ncommer...67&prmenbr=361
Old Dec 30, 2002 | 01:17 AM
firebirdkid's Avatar
Go with Edelbrock T.E.S. Headers. Comes with everything you need and are coated! (if you want) Here are the coated ones.
Headers
Old Dec 30, 2002 | 10:56 AM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
The Edelbrock headers are nickel plated not coated, deceptive little bastards aren't they Anyway they would last longer and look better than rusted old headers. Edelbrocks are supposebly the easiest to install and even their painted have a decent heat resistant finish. Search the exhaust board you'll find a whole lot of info.
Old Dec 30, 2002 | 01:32 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
The black painted Edelbrocks are not heat resistant...That coating burns off instantly. I put mine on, the coating burnt off so I took them off, sandblasted them and had them ceramic coated. Avoid the Edelbrocks cause the routing of some pipes causes problems with plug wire routing and access to the plugs are a pain in the @ss. Mine look good and function good too so besides that they are good.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
