AFPR for LT1 Converson??
Old Jan 4, 2003 | 05:35 PM
Formula383's Avatar
Car: 88 Firebird Formula
I just did a search to see what kind of AFPR people are using on the LT1 Conversions. I have a Aeromotive AFPR. This is one that is no good for the conversion because it does hit the Dist. (Not good to do). What type of AFPR are people using? John Millican I know you are using SLP's but I think you said you are using the hat only. Thanks
Old Jan 4, 2003 | 07:09 PM
ragtop88's Avatar
Car: '88 Camaro ragtop
Engine: 379 destroker
Transmission: m6
Axle/Gears: 10-bolt/3.42
Do you have any pictures? Are you trying to install the AFPR right to the fuel rail? I'm about to order the Aeromotive 13109 for this swap. Is that the one you are using? What about remote mounting is somewhere else?
Old Jan 4, 2003 | 09:39 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Remote mounting the FPR would require quite a bit of modifications to the LT1 fuel rails, including welding.
Old Jan 4, 2003 | 11:18 PM
ragtop88's Avatar
Transmission: m6
But if he is using the aeromotive AFPR than I would thik he was already going to come off the rails with some AN-6 fittings anyways, is there an easy way to make this AFPR work with the stock lines and rails?
Old Jan 5, 2003 | 01:04 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Yea I got an Aeromotive AFPR, and it barely touches the cap. I was thinking that it wouldnt fit bit it does.
Old Jan 5, 2003 | 08:27 AM
Engine: 4.0L
Yes, your case is differant becuse you are starting with a '93 intake and rails. Those rails must be modified to even fit with the distributor back there.
I didn't want people cutting up good '94-97 fuel rails just so they can run a remote AFPR, there are plenty of AFPR's that are made to directly mount to the stock fuel rail.
Old Jan 5, 2003 | 08:31 AM
Engine: 4.0L
Chris, ragtop is talking about a stand alone aeromotive AFPR since he's running AN fittings all over with braided steel fuel lines.
I'm glad the Aermotive AFPR you used (they make more then one) fit. I remember your e-mails with some questions about that.
For all other people considering an AFPR on the LT1 intake, I recommend the Accel '94-97 F-body AFPR. It is the exact same size as stock so it presents no fitment problems.
Old Jan 5, 2003 | 08:43 AM
S10Wildside's Avatar
Another option is the TPIS AFPR. They sell either the hat only (which is you cheapest solution) or the complete AFPR. It's pretty easy to install their hat.
TPIS also sells the -6AN fitting for the fuel pressure regulator.
Old Jan 5, 2003 | 08:05 PM
Formula383's Avatar
Thanks John for answering the questions. I don't have any pictures and the AFPR is the same number. I have the regulator on the fuel rail in place and you can see it touching the dist. there is even a little indentation into the dist.. With all the vibration I think it would be just a matter of time that the dist would crack. I'm sure Aeromotive puts out a good product but I think in this case it would not be good for the LT1 conversion.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
355tpipickup
Sep 4, 2015 05:32 PM
