can some1 expalin me where the fuel pressure regulator is?? please.
Old Jan 11, 2003 | 10:24 AM
carrascoZ28's Avatar
hi. im new on third gen camaros and tpi. im trying to figure out how the inyection works because the car smells gasoline and is eating too much gasoline.
thanks
Old Jan 11, 2003 | 10:37 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
The fuel press reg. is just in front of the distributor. It spans between the two fuel rails.
However, My guess would be that you may have a stuck injector. To check you will need a fuel pressure gague and connect it to the schrader valve at the passenger rear of the fuel rail.
Let the pump pressurize the fuel system and shut it off. If the pressure drops within a couple minutes. It might mean that you have a leaking injector.
To actually make sure you would need to unbolt the fuel rail from the intake manifold , there are 5 bolts, 4 on top and one in front.
Place a shallow pan under the rails. Pressurize the system (by turning the key to on, do not start!, then shut off. Look for any injector that is dripping fuel.
Just my .02
Good Luck
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
