What mods next ?????
Old Jan 13, 2003 | 07:40 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
This is my first time posting here so .....hear goes
I have a bone stock LB9 w/ 5-speed 3.08 posi ..... Ram air and a highoutput coil , And that is IT
I ran a 15.1 @ 93 mph with a 2.2 60ft'er ( )
I am looking for a good mod for next season ( 3.42's going in too )
Also alot of chasis mods ( get rid of that crappy 2.2 60 time )
All help is appreciated
I am kinda looking for a best bang for the buck thing ..... but all input is greatly appreciated
Thanx
Old Jan 13, 2003 | 09:09 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I think bang for the buck means different things to people of different means; But, from where I come from the best bang for the buck on that Lb9 would be a set of headers. Another great bang for the buck would be a supercharger- bigger bang and bigger buck.
Old Jan 14, 2003 | 03:52 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
cooolio ....gotcha on the BIG BANG I like the idea of the headers ..... thanx for the input
Old Jan 15, 2003 | 08:33 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Full tune-up if you haven't done one. All of the free mods, and then I would agree with the headers. You can find more ideas at the thirdgen.org homepage under tech articles.
Old Jan 15, 2003 | 08:41 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
definatly headers and a good flowing exhaust. maybe intake and cam. Might not hurt to have some drag radials either.
Old Jan 18, 2003 | 04:44 PM
Iroc n roll's Avatar
I know people usually overlook this when thinking about "performance" mods, but if you are serious at all about this car go out and get some subframe connectors. Just about every car I've ever seen whether its a hard top or T-top has developed stress fractures from the frame tweaking under hard acceleration, and thats on stock motors. It was the very first mod I did and in my opinion it is the best starting point. More power will only lead to more frame problems. Weld on subframes are best. If you have T-tops go get some immediately.
Old Jan 18, 2003 | 07:01 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Yes sir Sub-frames! Cheap, and cheap to have installed, and abso-freakin necessary. They are my next mod, as I was "forced" into souping up my 700R4 after it threw up all over itself during a race.
Old Jan 19, 2003 | 01:06 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Well guess what ?! Some guy ( before I owned it ) had the tranny mount bolts snap ( the outside ones on the tranny crossmember ) So .... he cut a hole in each side of the subframe......and drilled new holes ( so he could "pop" new bolts in) . The thing is ....those factory bolts are in a plate ( displace pressure through the suframe) welll..... this new " fix " just had the bolts "popped" through the holes ( with no washers or anything !!!! ) ......well I have "torn" them through the chasis .
Moral of the story is ................ get you SFC's NOW !!!!!!!!!!!!!!!!!!
definately on my list of to do's come May 1 ( along with a total frame repair, etc ) .......Totally done right !!!!!!!!!
Old Jan 19, 2003 | 03:32 PM
Zenger's Avatar
first some M/T E/T streets
3.42's
stall convertor
then get your exhaust worked out
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
