Is the MSD dist. worth the money?
Old Jan 15, 2003 | 09:04 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I was looking at the Distributor MSD offers and it doesn't seem so trick. I mean it's got ball bearings and all, but the rest seems pretty plain. Will it give me better performance or HP. Or should I just stick with my stock one???
Old Jan 16, 2003 | 12:57 PM
Jza's Avatar
Jza
Nope. In that case, it's really more about reliability and durability than true performance. I'm not saying it won't help at all, but if you're looking for a performance boost, rather than a part upgrade to support another upgrade, then it's the wrong place to look. If you're looking for a part that can stand up to some hard use and high rpms without a hiccup, then you're there for the right reason.
Old Jan 16, 2003 | 01:22 PM
ckeene502's Avatar
i put one on my wifes 89 rs the other month after the stock one killed over. it was made so much better than stock i could not believe it. did not make it faster but idles alot better.
keene
Old Jan 16, 2003 | 02:18 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
I was going to get a new one too for my new motor, but came to the same conclusion! I just rebuilt mine with new parts since it only had 81k miles on it and when it goes out then i'll get a new one.
Old Jan 16, 2003 | 08:40 PM
Hung Start67's Avatar
Horsepower no. Performance no. Having a quality dist as the MSD part in your motor when you are trying to keep the candles lit..priceless..
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
