lt4 hot cam ( again ).
Old Jan 17, 2003 | 03:58 AM
devilfish's Avatar
How will a hot cam work with the stock TPI?
Im going to swap out the TPI later, but right now im just going to install a cam.
I know the TPI will hold me back now. But will it run stronger then stock?
Regards
Old Jan 17, 2003 | 11:47 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I used to have a stock TPI on my car. I had some sportsman 11 heads, Hot Cam, 350 blah, blah, blah. I ran it at the track with 2:73 gears and got the best of 13.0 @ 108.78 I think it worked good.
Old Jan 17, 2003 | 01:17 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Not too good with numbers and cam specs but the hot cam makes power at higher rpms than say a stock tpi unit is used to or even some ltr set ups. I think anyway! RU QWIK seemed to have good results though.
Old Jan 17, 2003 | 02:30 PM
devilfish's Avatar
auto?
what whas your 60 time?
I got 6spd with 3:45. I think 12sec is possible ! And I have a vette,,,
f-bodyz28
Sep 2, 2015 05:03 PM
masonta
Sep 1, 2015 06:40 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
