LT1 Intake Swap - Throttle Body Coolant
Old Jan 20, 2003 | 04:26 PM
S10Wildside's Avatar
On the TPI intake, the coolant port on the front of the IAC housing went into the TPI base. Where does it go for the LT1 intake swap?
Old Jan 20, 2003 | 05:00 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
www.LT1intake.com
You'll find answers to most of your questions there...
Old Jan 20, 2003 | 07:47 PM
I've been trying to get to John's site all day. It must be down or removed. He has a coolant diagram there.
Old Jan 20, 2003 | 07:54 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
My site's been down all weekend. I have a trouble call in with my hosting provider.
The LT1 intake assumes you will do a TB coolant bypass. If you really want hot coolant flowing through the TB then route the 5/8" coolant hose from the remote t-stat to the TB then to the heater core.
Here's my diagram (shows a TB bypass setup).
Old Jan 20, 2003 | 08:17 PM
My only concern is that the throttle body would freeze up at cooler temps. I put this vehicle away for the winter, so it won't see anything less than about 50 degrees.
Thanks for the diagram, John.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
