throttle body bypass
Old Jan 22, 2003 | 03:45 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
ive searched around and didnt find a lot of good info
-what exactly is a tb bypass, i mean, i can sorta figure it out by the name obviously but what good is it, how can u do it, and why would u? thanks
Old Jan 22, 2003 | 06:29 PM
llvll4l2c91350's Avatar
A TB bypass on a TPI engine consists of disconnecting the hose that goes from the manifold to the TB, and the hose on the other side that goes out of the TB to the heater control valve. You join these together and bypass the TB. The purpose of this is so the throttle plates don't freeze in colder climates. The downside is that it could hurt performance because the hot coolant could warm up the air going in the engine, and warm air = less power. I dunno how much improvement in performance, if any, you get out of doing this. But it made sense to me that if the TB is warm or hot, then the air passing thru it has to warm up.
Old Jan 22, 2003 | 06:33 PM
383 rocket bird's Avatar
There is an article on this subject in the technical articles section of this site.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
