junk yard shopping..how do I know its a 350/305
Old Jan 27, 2003 | 08:44 AM
blk86ta's Avatar
they look exactly the same, so how can I tell? I'm not taking the word of the yard guy, I've been screwed by that befer. thanks,
Jason
Old Jan 27, 2003 | 09:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: junk yard shopping..how do I know its a 350/305
Jason
The newer engines (don't know when they started) have the size in liters cast into the block.
Drivers side rear cast into upper bellhousing area. Look for 5.0 or 5.7. Can't go wrong.
RBob.
Old Jan 27, 2003 | 12:03 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
i could be wrong but i believe the fuel line will enter the rails on the driver side on a 305 and they will enter the rails on the passenger side on a 350.
Old Jan 27, 2003 | 12:11 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
wrong
Old Jan 27, 2003 | 12:17 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
am i backwards or just completely wrong? i know that i have seen them come in on different sides before
Old Jan 27, 2003 | 01:16 PM
Jza's Avatar
Jza
You're close, but for the wrong reasons. If the fuel lines come off the passenger side, it's gonna be a 350, but only because it's a Corvette motor. If they come down and to the driver's side, it could be either size.
Old Jan 27, 2003 | 02:01 PM
jared C.'s Avatar
you could always look at the catalist. says the engine size right on that
Old Jan 27, 2003 | 02:04 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
jza-
my bad- i just assumed they (350's) were all the same. well good deal- one more part that is from a vette- on my engine in my s-10. just one more thing that makes my license plates make more sense (one more vette part that i didnt know i had- the tpi unit or at least the fuel rail) not that the fact that it comes from a vette makes it any better- they are all more or less the same. but i just like to come up with clever plates. in case anyone cares my plate reads- 1_SVETTE a well balance mix of a vette and s-10
Old Jan 27, 2003 | 03:12 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
The '87 on up blocks have 5.0 or 5.7 displayed right behind the drivers side cylinder head.
The '86 and older have casting numbers which you will have to look up. If the heads are off, you could always just measure the bore
Old Jan 30, 2003 | 08:47 PM
bigals87z28's Avatar
Car: Check The Sig
HEY!... if ur lookin for engines that are still in side the car, check the vin? yea, sometimes they get swapped in... but best bet is to go lookin for the vin... anyway.. .86 didnt have and 350 sold in birds or camaros... so there is no 350 in 86, unless its a vette, where its a 350 no matter what... so its all good... there u go
86IROC112
Nov 7, 2015 06:50 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
