Is to much air a bad thing?
Old Feb 2, 2003 | 10:29 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
how bout this box? their still not done..
they are going to be sealed all the way from my foglight opening to the filter...
These mothas are going to flow some air...I shot air into them with my blower and couldnt believe it...It felt just like the blower!...
I did the blower thing along time ago when I just had the stock air inlet with the tops cut out and couldnt even tell I was blowing air into it...
SO is to much air good or bad?
Old Feb 2, 2003 | 11:23 PM
Morley's Avatar
Air is always good, just make sure you don't pick up water in that scoop, MAF's HATE water.
Old Feb 2, 2003 | 11:25 PM
I dont ever drive in the rain......cause I dont have any tread...LOL
Old Feb 3, 2003 | 06:39 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
That kinda looks like the setup I made for my Camaro a few months ago. Here's what mine looks like:
Do you have any more pictures of your design? I'm planning on redoing my air intake with "real" sheet metal (I just used metal flashing) and that body filler caulk material.
Old Feb 3, 2003 | 07:08 AM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Those are the ones you got off Ebay and they newer styed ones that seal up if thats what I saw in another thread?? Id like to give them a shot as well and have difinitive numbers from the track when it opens in March as to them working or not, got the guys Email address that you got them from??
Old Feb 3, 2003 | 07:29 AM
bigals87z28's Avatar
Car: Check The Sig
nice guys... where did u get them or did u make them? thirdgenZ28.... im PMing u on our next meet... i would like to see more central jersey boys so we can have the meetings moved further south....
Old Feb 7, 2003 | 05:39 PM
rezinn's Avatar
Yes everyone has these. There are plans for them on the internet somewhere. If you've got a protractor(maybe not), a ruler, some sheet metal, and a rivet gun or some nuts and bolts, they're easy to make.
I don't think you'd benefit from caulking or "real" sheet metal.
Old Feb 7, 2003 | 08:18 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Right, metal flashing probably isn't any different than regular sheet metal, but the main reason I'm redoing it is because I'm going to round off the 90* transition so the air won't have to hit a flat surface; it'll be more gradual and should (theoretically) flow a little better. The caulking will seal up the whole assembly and prevent any air leaks.
eightsixseven
Dec 16, 2024 01:50 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
Bob88GTA
Aug 18, 2015 03:31 PM
