Good News and Bad News
Old Feb 3, 2003 | 06:44 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Well I got good news and bad news, I'll give you the bad news first.
Fixing Code 33 didnt fix my intermittent starting problem.
Good News: I might have found the problem now.
When it doesnt start, I can unplug my coolant temp sensor and start it up no problem. Its a new CTS in a remote thermostat housing and my computer isnt throwing any codes.
Is the new CTS bad?
Old Feb 3, 2003 | 01:39 PM
86FyrBrd's Avatar
anyone?
Old Feb 3, 2003 | 01:55 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I'd guess i read this board as much as pretty much anybody. And you know what. I have no idea what your intermittent starting problem is.
Translation, a thousand strangers online are not following your saga with interest. Can we have a summary of symptoms and things you've checked up to this point so we can attempt to give you a hand.
Old Feb 3, 2003 | 02:15 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
To double check your CTS, get ahold of a new one (again) and plug it into the harness before actually installing it into the remote coolant line. If it starts, go ahead and install the new new sensor and throw the old new sensor away or return it as an out of box failure to whomever you got it from.
FYI, I'm following your saga...
Old Feb 3, 2003 | 03:32 PM
Ed Maher's Avatar
Car: 04 GTO
OK, to be a little more helpful on my part , if you do some searching, Vader has posted a table a few times that shows the resisance of the CTS across the operating range. You could use that to check to see if it is working OK too.
Old Feb 3, 2003 | 06:55 PM
rezinn's Avatar
I am not following. Got a link to old posts?
Old Feb 3, 2003 | 06:56 PM
rezinn's Avatar
It did throw a code when you started with the cts unplugged, right?
Old Feb 3, 2003 | 10:17 PM
86FyrBrd's Avatar
Yeah it did, I'v done it twice, the first time it did, 2nd time it didnt.
Old Posts:
https://www.thirdgen.org/techbb2/sho...t=intermittent
Another thing that may help is it seems to only do it if it is warmed up then run for a second and turned off, like if I come home, start it, move it across the driveway, and stop it, then try and start it again within an hour or two.
but like stated above, I have found out if I unplug my CTS it starts up.
Old Feb 4, 2003 | 02:29 PM
leirch's Avatar
Do you have a scan tool? Diacom/Moates?
With the changes you've done to the motor, could be a tuning issue. Have you tried holding the gas pedal down all the way and then crank when it won't start?
Try that
With the CTS unplugged the ecm is seeming a 255d(or whatever the highest number is), which could be dumping less or more fuel or possibly be changing the cranking pulsewidth and lets the car start.
Just a thought.
Old Feb 4, 2003 | 02:55 PM
86FyrBrd's Avatar
Today it wouldnt start, I swapped in the new CTS and just hung it there to see if it would start, it fired rite up. So Im figuring thats what it is.
Now I just have to put it into my remote T-stat housing in place of the old one.
86IROC112
Apr 9, 2016 10:20 PM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
