EGR was disconnected w/no codes?
Old Feb 10, 2003 | 03:43 PM
Recluse's Avatar
Is this possible on a 88TPI? Mine has always been disconnected and I get closed loop operation but no trouble codes. Should I get a code...I mean the solonoid isnt even there but the valve itself is but not connected to a vacuum source. any Ideas?
Old Feb 10, 2003 | 06:10 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Could just be dumb luck. 32 only sets under very specific conditions, which is like very steady state cruising in a pretty narrow range of speed (like 45-65 or so IIRC) for a few minutes. So if you don't do long highway drives with the cruise on, you might never even get into a situation where it got checked. Or some other dumb luck.
Old Feb 10, 2003 | 06:57 PM
Recluse's Avatar
cruise doesnt work either..heh heh.
Old Feb 10, 2003 | 11:22 PM
383 rocket bird's Avatar
My solenoid was gone and the valve was not functionaland i never had a problem. Now that i rebuilt the motor I am having EGR issues. Guess that is just one more reason to start burning my own chips.
Old Feb 11, 2003 | 09:27 AM
Guest
Guest
Posts: n/a
I've never had a MAF car set that code with everything disconnected. Doesnt sound so odd to me.
Old Feb 11, 2003 | 10:05 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
mine will only set the code 32 on long highway jaunts at steady speed. mine is all hooked up and functional, but i think my cam and intake mods may flow enough more air that with teh stock chip the computer cant tell that the egr valve is open, so it sets the code.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
