Need help with cam choice for 400
Old Feb 12, 2003 | 11:51 PM
mastrdrver's Avatar
Right now I'm down to the cam selection, but didnt know if it will work with sd. Right now have a 400 sbc with lt headers, MR or HSR, and AFR 220. I'm putting it in a 90' formula with a t56. The cam I'm going with will be the XER 242/248 112 LSA, but I don't know if it will have enough vacum for the sd to work. I dont want to get this all done and find out that the thing wont run bcuz the cam is too big.
Thanks for the help
Jeremy
Old Feb 13, 2003 | 04:02 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If you are worried about it you can always get a vacuum booster.
Old Feb 13, 2003 | 08:45 AM
mastrdrver's Avatar
Will that solve the poor vacum signal for the MAP sensor that happens with bigger cams?
Old Feb 14, 2003 | 08:06 AM
chris400's Avatar
take into account that a 400 usually "swallows" a cam...
do a comparison on duration.
a 305 with a HOT LT4 cam, and World heads runs fine with a gm ecm and speed density.
the HOT LT4 cam is 219 / 229 on 112lsa
If it were me, I'd get a copy of Desktop Dyno, and do a cam comparison based on your setup.
I found out when I was playing with similar cams on mine, that a cam with shorter duration and a bit more lift made more power.
I'm going that route, to make sure there are no programming issues.
I found one with 230 /238 on 112 lsa that should scream.
given the difference in displacement, it should do fine for drivability.
good luck!!
my .02
chris400
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
