Removing cat Bad or Good?
Old Feb 17, 2003 | 10:35 AM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
I am thinking of removing the cat. Is this going to be a good thing or a bad thing? I heard that I will be loosing backpressure.
Old Feb 17, 2003 | 11:48 AM
mikobu3's Avatar
i removed mine lastyear on a 86 305 tpi ,,terrible gas milage put the cat back on and got way better gas milage,,, also you loose a little off the line
Old Feb 17, 2003 | 11:53 AM
CEDOE's Avatar
As far as backpressure goes i dont know,but i can tell you that after removing mine i noticed no difference in power or anything.(I removed mine cause it was bad and sounded like rocks in a tin can being shaken up)
Old Feb 17, 2003 | 02:09 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Neither of those makes sense to me...
Old Feb 17, 2003 | 02:13 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
good.
Back pressure? So I guess that's why so many race cars don't have any exhaust. They don't want to go fast. Or maybe they just don't like the loud noises.
Why do you swap manifolds for headers?
Why do you put on a cat back w/ a less restrictive muffler and bigger pipes?
FOR LESS BACK PRESSURE
There was a great technical article that broke everything down and explained how backpressure is bad and why people think that you can have too little of it. I wish I could find it, but yet again, the search isn't working.
ANYWHO, if you want some gains, gut the cat or take it off. Or even replace it w/ a high flow unit if you want to stay emissions friendly. There's vertually no difference in power between a highflow cat and no cat. But the stock cat does choke it up.
Old Feb 17, 2003 | 03:49 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Right it's one of those things that you KNOW is helping whether or not you can FEEL it.
Old Feb 19, 2003 | 12:56 AM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
just gut it. i've done it on every f-body i've had and it hasn't stopped me from passing inspection. the car has always run as good or better.- although maybe a little louder.
Old Feb 19, 2003 | 10:28 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
A gutted main cat isn't a good idea unless you put a straight pipe through it. The sudden loss of velocity hurts high end flow, though it does help exhaust scavenging for low RPM torque production... There are better ways without trading off so much on the top end...
Old Feb 19, 2003 | 12:31 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
for the little bit of power you lose, im 100 times happier with it on. i think its a dumb idea to take it off honestly. first off there are laws for a reason. second, its nice to breath some decent air once in a while and third, id never pass inspection without it.
dont see why you would take it off for the ~6hp you gain.
Old Feb 24, 2003 | 08:17 PM
DH1987TA's Avatar
One problem you may run into...EGR system works off of exhaust backpressure. Too little exhaust backpressure will result in a low EGR flow, which can cause high combustion chamber temperatures and detonation.
Darrell
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
