Those with SuperRam and/or 58mm TBs
Old Feb 21, 2003 | 12:29 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
This is for MAF cars only.
I just installed the SuperRam base, plenum and runners and the TPIS 58mm TB on my 89 Iroc.
Since the TB is much 'thicker' than the stock one I can no longer use the accordian looking rubber piece that fits between the MAF and the throttle body. I don't know if the SuperRam sticks out furthur forward than the stock plenum. If so that may be adding to the problem but I only have about 3" of space between the two and don't want to cut the stock rubber piece. What did you guys use to seal that space? Any suggestions are welcome, thanks.
Old Feb 21, 2003 | 01:51 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I sandwiched the stock piece. The only way to do it is to bring the air filter lid together w/ the MAF at an angle. Start with both the MAF and lid slanted upwards and towards each other like this: / \ Then bring them down together while sliding the MAF into the lid. The accordian piece will be smashed together VERY tight as you secure the lid to the filter housing.
Old Feb 21, 2003 | 02:04 AM
BuckeyeROC's Avatar
If you absolutely cannot make the stock piece work, the LS1 guys use some type of intertube type stuff. My Stealth intake came with it, but I do not remember the proper name for it.
Old Feb 21, 2003 | 09:01 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I guess I'll try that again. The first time I didn't have the leading edge of the air filter lid in place and it didn't want to work.
Old Feb 21, 2003 | 10:43 AM
BuckeyeROC's Avatar
Yes, you do need to have the front edge of the lid down by the housing when you start.
Old Feb 21, 2003 | 11:30 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
If you can't get it to work, try big rig intercooler couplings. You can get them at most big truck service centers.
Old Feb 21, 2003 | 12:01 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
http://www.bakerprecision.com/ sells the turbo/super charger type reinforced silicone tubing by the foot as well as specialty adapters too. I used a 4" to 3.5" adapter on my TB to go to my cold air pipe, then got one foot of the 3" hose to connect the tubes. Of course mine's not a Camaro like yours, but you should be able to find what you need there.
Old Feb 21, 2003 | 07:19 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Thanks for the help!
Old Feb 23, 2003 | 07:23 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I don't have a bigger t-body, but what works best for me is assemble the rubber accordian tube, MAF, and intake Y first. Then slide the rubber tube over the t-body lip and seat it fully, tighten it down, then compress the tube by pushing on the Y and set it down into place and lock it. Works fine for me.
Old Feb 24, 2003 | 12:50 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Well it worked for me this way. Very tight fit though. Thanks again
Old Feb 24, 2003 | 04:20 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
has anyone made a bigger MAF for our cars?? i see ls1s and ricers with like 85mm mafs..
Old Feb 24, 2003 | 04:54 PM
BuckeyeROC's Avatar
No problem. There's not too much room left is there? I don't think the plate will fit for my N2O, I might need a fogger nozzle.
Old Feb 24, 2003 | 06:32 PM
Bort62's Avatar
That, or a 7730
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
sailtexas186548
Feb 17, 2017 03:07 PM
IROCNParts
Sep 24, 2015 10:50 AM
