aftermarket tpi rpms , out of air when ?
Old Feb 22, 2003 | 03:13 AM
87t/a gta's Avatar
hi i was wondering a when a tpi with accel runners ,
lowwer intake , matched plenum . 58mm throttle would run out of air , what rpm range would be good with a car that has a stick ?
thanks chad
Old Feb 22, 2003 | 11:12 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I don't know what the MAX is, but I know that my '87 which has Accell base, AS&M Runners, ported plenum and a Holley 52mm Throttle Body and I can pull up to 5500 RPM. I have never taken it past 5500 (too scared). When I dynoed, my peak of 349.6 TQ was at 4100, but at 5,000 RPM, I was at 275 ft/lbs at the rear wheels. I'm loosing 75 ft/lbs of TQ from 4100 to 5000, but I can tell you, driving it up to and past 5K, it doesn't feel like I'm loosing it. It revs freely and pulls respectivly.
Old Feb 22, 2003 | 02:17 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
What RPM was your HP peak at?
Old Feb 22, 2003 | 02:38 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
About 4350 RPM
Old Feb 22, 2003 | 03:22 PM
rezinn's Avatar
I've been claiming at least an additional 500 rpms over stock with siamesed runners and a matching base and plenum. Thats about 5300 compared to stock, so I'll concur with GMTech. AS&M runners are siamesed deeper than mine, though, which could account for a couple hundred more rpms.
Old Feb 22, 2003 | 03:38 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
My AS&M runners are not siamessed.
Old Feb 23, 2003 | 12:01 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
About 4350 RPM
4350?? Really? That's lower than stock isn't it?
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
92purpz28
Aug 11, 2015 02:30 PM
