Trickflow heads
Old Feb 26, 2003 | 10:21 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Trickflow heads
Anybody have experience with these? What is the main difference between their 23º heads and their G2 Twisted Wedge heads?
How do they compare to Edelbrock Performers?
Old Feb 26, 2003 | 10:46 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I've got the 23*'s and I feel they are fine. I'm running them with an Xtreme cam and SuperRam. Havent taken it to the track yet but man does it scream.
Old Feb 26, 2003 | 11:43 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Any specs on them? I have a set of Crane Gold 1.6RRs (non self-aligning) that I would like to use along with my ZZ9 cam.
Old Feb 26, 2003 | 11:49 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Specs? Well 64 CC 195's D port Exhaust, centerbolt ones with heat crossovers. I have the upgraded springs for up to .540 Lift. I run standard Comp Pro Mag 1.6 rockers. NSA ones. Cam is 218/224 .495/.503 (with 1.5's) and 112 LSA
Old Feb 27, 2003 | 12:19 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Thanks. Are they smog legal? How much were they?
Old Feb 27, 2003 | 12:35 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You need $500 worth pistons to go with the G-2 heads
Old Feb 27, 2003 | 12:38 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
What do you mean? I have dish-top pistons in my motor now, will they work?
Old Feb 27, 2003 | 07:09 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Depending on how big your cam is, will depend on what pistons you need with the G1/G2 heads. Because of the "canted" or "twisted" design of the valves, valve-piston interferance needs to be taken seriously. If you want to run over .500" of camshaft lift, you need to get pistons that will clear the valves. I used dished pistons w/ 4VR for use w/ my ZZ4 camshaft, but TFS makes domed pistons that will work. I would reccomend the 23° heads over the G1/G2 series. Because of the "twisted" valve design, they are prone to pre-mature valve guide failure (especially on the G1 heads).
Old Feb 27, 2003 | 07:27 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
That's exactly the info I was looking for. Thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
