Fuel Pressure Problem
Old Mar 2, 2003 | 06:14 PM
Jas89TTA's Avatar
On a 89 GTA with a 350 TPI, The car will not start unless you spray staring fluid in the TB and it will fire up, On the fuel rail were the scrader valve is you can press it in and there is no fuel coming out, Could this be a fuel pump relay, or fuel pump problem? Any info or suggestions would be great, Thanks, Jason
Old Mar 3, 2003 | 12:34 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
When you turn the key to the 'ON' position do you hear the fuel pump turn on? If not then check your fuses.
Old Mar 5, 2003 | 11:24 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
My car is doing the exact same thing.... I think the problem is either the fuel pump or the fuel pressure regulator, I'm not sure which... You can test the fuel pressure on the fuel rail with the key on, and then with the car running. You need to remove the vacuum hose from the regulator to get an acurate reading. Should be about 44 psi for a TPI system.
My car shows about 22 PSI with the key on, 44 PSI when running.
Old Mar 6, 2003 | 08:20 AM
ajm_shorty's Avatar
My car is having a similar problem...Ithink its the check valve in the fuel pump...I tested my pressure..It went up to 41 or so and dropped fast.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
